This is just me personally and what I would do but... I would believe this is a proper candidate for the board being cut in half with a jigsaw. The left-hand side dominated with IC Chips, until just to the right of those MLCC's would absolutely be a HGT board. I would also consider removing those capacitors just because then it will be a nice flat board with chips and connectors and no junk. The lefthand side dominated with transformers, even with all of them removed looks pretty worthless IMO... I would remove that connector on the other side and put it with gold connector ends if it has gold and the rest of the board without any transformers would be a mid-grade board.
If you aren't chasing exact sorting "maybe" that board with just transformers and capacitors removed would be high grade peripherial...It's just the value to me is on the left-hand side only.
_________________ --- **Please keep in mind that my assessments on board quality are personal in nature
Abbreviations HGT - High Grade Telecom LGT - Low Grade Telecom HGP - High Grade Peripherial LGP - Low Grade Peripherial MGB - Mid-Grade Board LGB - Low-Grade Board
