PostPosted: Wed Jan 31, 2018 10:34 pm
First timer I tried to sort label and weigh everything to the best of my abilities also the scale was set to grams.Would i put everything inside 1 box and ship it would it be worth it.I would appreciate all of the feedback given thanks a bunch....Rich
PostPosted: Thu Feb 01, 2018 4:09 am
Oh my. So many photos in a single post! ;)
I’ll hit it all in a few hours
You’ve got some good stuff mixed in here so I’m gonna give it it’s due in a few hours. Answer by mid day.
PostPosted: Thu Feb 01, 2018 2:05 pm
Ok can’t wait thank you!!!
PostPosted: Thu Feb 01, 2018 5:35 pm
Unsure: the motors they don’t take. The old drive board with the finger is gold finger card. The brown rather empty board is low grade. And drive motor boards that are metal boards are low grade. Drive motor boards that are standard pcb boards go as midgrade.
The two brown boards with gold pins are peripheral. The remainder look peripheral including the two smart remote boards.
Xbox drive. There’s a standard hard drive inside. The connector board will be either hard drive board, peripheral, or telco depending on the variant inside.
Xbox: peripheral remove heat sinks. Sink will be copper aluminium heat sink
Dish: peripheral
Cell boards. Please remove any non soldered heat spreaders. The Sony memory adapter board is peripheral
More cell stuff see above
Computer boards: I see peripheral on top. A controller of some sort below it. A bunch of gold finger cards.
When you click on image it rotates so her we go. Left column:
Gold finger card
Telco
GFC
Midgrade
Right Column
GFC
GFC cut off spreader
Telco
Telco
Big pile: big
Parts:
Click to rotate
Left column
Telco
Telco
Cd/dvd
Peripheral
Middle column
Backplane
GFC
Telco
Peripheral
GFC
Peripheral
Right column
2 peripheral
Peripheral
Peripheral
2 GFC
Left two GFC Middle peripheral right midgrade
Pile
He boards
Broken board is gold pin connector
The wide rectangles with the M chip are Cd/DVD boards
Silver ram
Gold ram
Processors
CPUs rotates
Left column
Green brown fibre with metal
Green brown fibre without metal
AMD ceramic (no cap here)
Right column
Pentium gold cap
Large socket
Small green socket
Large socket
Small green socket
Large dual socket
Large socket
PostPosted: Thu Feb 01, 2018 6:26 pm
So the grades go 1 telco(being highest) 2 peripheral 3 Low grade Iam still lost so would I just put everything in 1 box and they will sort and grade for me?Does gfc mean gold finger card?
PostPosted: Thu Feb 01, 2018 7:20 pm
they well but at a huge pay decress its in your best intested to keep it seprated or you will only lose money.
yes it dose in this case
also the 360 hardrive has vaule as a whole in places like gamestop,game exchange vintage stock extra even the shell without the harddrive just the plastic case and the board has a bit of trade in or resale value.
PostPosted: Thu Feb 01, 2018 7:23 pm
Yes GFC is gold finger card. You can use one box but there needs to be some level of sorting on your part. Stretch wrap and cardboard sheets (inserts or the side of large boxes) work best for keeping boards sorted in transit.
The quote form under sell material at the top has all the various grades.
General boards go telco at the top end, peripheral, mid grade, low grade.
Motherboards are also sorted out by tiers.
The gold finger cards and cell phone boards, cd/dvd controllers, and hard drive controllers all have their own classes.
Ram is sorted by colour and if it has a heat spreader (rambus) or not.
Click on the sell material link up top and scan through the list.
